90-30 Bit Operations
jvcontrols
Apr 2011
BC
Hi, I'm a "bit" confused with shift registers for the 90-30, cpu 323.
I'm trying to start a group of 16 motors in sequence using a shift register. How do I write the %R's to %Q's?
Hi you can simply use MOVE
make sure you target a byte boundary for your %M bits
eg %M0001 / %M0016 etc
why not use shift bits. Once you pick Shift Register change type to bits instead of word.
Try this. Every scan in which both %M0001 and %M0002 are true and %R00001 has the value 1, you will shift the bit pattern of the sixteen bits starting at %Q0001 by one place and move a 1 into the vacated LSB.
You can clear all sixteen bits by putting the value 16 into %R00001, turning %M0002 off and turning %M0001 on.
|%M0001 +-----+
+--] [---+ SHL_|
| | WORD|
|%Q0001 -+IN B2+-
| | LEN |
| |00001|
|%R00001-+N Q+-%Q0001
|%M0002 | |
+--] [---+B1 |
See the screenshot of EIP tag list. We are trying to read in a digital input that is hard-wired. It is shown here as I31.1. I believe we cannot...
302
A couple days ago I accidentally toggled an alwasyoff bit. The issue is it was set up as a single OTU on a rung, nothing else, and used as XICs...
235
Hi I have an old panel builder 32 that I’m replacing for a factory talk me hmi . In the plc for the old panel builder there is a coms bit for the...
83
Hello, Haven't been on in a while. I need to generate a bit level pdf of the I/O for RSLogix 500. I can generate a report but it just shows the...
174
I tried researching but I still don't quite get it. As far as I understood, it's used after a function is called in STL and then if the function...
153
