90/30 conversion to Rx3i
Orator111
Nov 2011
Orlando
I'm considering replacing some 90/30 processors/racks with Rx3i processors/racks and keeping the existing I/O cards. Does anyone know of a publication that discusses the advantages and pitfalls of doing such an upgrade?
thanks!
thanks!
I don't know of any publications that discusses this, but I have done this exact thing with no issues.
thanks!
I suggest you have your local rep stop in to explain it to you. They can then take a look at what you have and help you avoid any "gotchas" like unsupported or too old modules.
I think being proactive is great but the hardest sell is spending money to fix what isn't broken. While there are some unique options with the PAC, it may present some problems with prerequisites that may need to be solved before you can utilize said advantages further adding to total cost of conversion. If its just going to be a retrofit mission where you import the logic to a new cpu then it may be a easier transition. We are adopting an end of life approach to upgrades/updates.
I have 4 systems that are 90-30 and I am converting to RX3i. IO Modules are the same 90-30 modules and are compatible. I am replacing 90-30...
7,912
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
230
Currently I’m using ESA model VT155W0000 HMI and it’s communicate with Fanuc PLC. Can any one suggest can I convert ESA model to EXOR HMI eSMART07M
113
hi... i have an issue in s7 300 plc, while we run the machine(in idle there is no fault) , plc cpu goes in SF mode, after restart the power cycle...
144
I have a Type C to RS485 adapter connect to my Siemens RWF55. I use modscan to scan it to get a value from the Siemens controller. In the...
113
