A-D MB-Gateway on Koyo DL260/ECOM100
bartb102
Dec 2012
Albany, NY
OK, I'm having trouble understanding correct addressing to read data from the MB-Gateway Automatic Read registers.
I am reading data from the MB serial slave using an ECRX block, and a peer-to-peer setup in the PLC's ECOM.
I believe I have configured the MB-Gateway to auto-read data from the serial slave.
I cannot read the auto-read data from the gateway into the PLC. Too many "ID"s.
ECRX sends its message to Slave ID 4
ECOM100 has a peer-peer device 4 configured to TCP device at 192.168.5.104, port 502, ID #2 so the read message is sent to serial MB slave #2, which responds. Works fine, but with occasional comm errors.
Gateway Modbus Address is set to 4. I have tried changing to 5.
How do I address the MB-Gateway data space that contains the data automatically read from the serial MB slave?
Any help would be gratfully accepted.
The best thing to do would be to get in touch with technical support. It's free and you will be up and running very quickly.
AutomationDirect.com
1(800) 633-0405
Hi All, Has any of you tried to change the IP Gateway of the PLC (of course, essentially of the ENBT card), while in a redundant configuration...
150
We are trying to poll data coming from a PLC for remote monitoring we have the IP address of the PLC and the default port number and the path is...
25
757
Hello. I am trying to use a Prosoft AN-X4 to improve the communications for a new panelview plus 7. This is going from a SLC-500 through DH+ to a...
328
I have been looking to this and thought I'd ask for input from others before I take it in a wrong direction. The guy who used to set these up...
440
Hi, I recently installed 2 1783-NATR devices into two of our machines. The machines are pretty much identical, both having 1769- L24ER-QFC1B...
316
