a question for motion control
angi
Jan 2010
us
361
Hi guys
a question for E-Stop Kenitix 6500, when E-stop, does the server remenber actual position so can move from there when de-actived E-stop, or we need to write some code in PLC to make sure server remember the position.
thanks
Hi guys
thanks
Yes and No
Depend on what happens to the kinetics 6500 when you E stop it
If you maintain Power and uses the Safe Off then yes
If you remove power then the servo uses the Absolute Zero when it powers up IF you have used Absolute Zero to zero the axis then Yes - If you have used a different Zero method or Motion redefine Position (MRP) command then No
Hello all. I stepped into an established system to integrate a Fanuc Robot to tend machines that are using CLX's. I have seen many a machine use...
1,133
I am working on a small press that will utilize a Delta controller and a double acting hydraulic cylinder. The customer needs very precise...
5,024
I am studying AB 1756 MO2AE module's manual. The manual says that the module connects to a servo drive. This doesn't make sense to me. I...
3,304
hi guys i need to know the Actual position of one Axis, do i need to use GVS to get the value or just directly use the value in the...
4,436
Hi guys I am new for motion control, one question about how to start and stop Kinetix 6500? As we know that for VFD, there are Tag.start and...
2,281
