AB 1400-PD51A Power Monitor Configuration.
sparkytex
Jun 2013
Port Hardy B.C.
354
Hello guys,
Has anyone on here dealt with the Allen Bradley 1400 series power monitors? At our mill we have several 1400-PD51A ser. A power monitors on a DH-485 communications network to a PLC 5. In order to communicate over a netowrk you need a 1400-DCU comunications card. One of our current power monitors has failed, but we do have a spare with a spare 1400-DCU card (which is lucky). My question is how do i configure the new power monitor to communicate over the DH-485 network. Apparently they are done on a node system or unit ID, so i will need to configure the new power monitor's node or unit ID to match the old, how do i accomplish this. Do i need the power monitor software from rockwell, or is there another way around this? Thanks, Tex
91
I have a micro1400 processor running two routines (transfer compression/compression molding press). Recipe parameters are stored from job to job...
79
123
Hi, I'm having an issue with a mircologix not transmitting out. The current setup is a mircologix 1400 connected to a Guardian 100 Radio...
123
Hi, I am working with a Micrologix 1400 model 1766-L32BXB. With no input wires connected to the “in12” thru “in19”, I am getting 24 volts while...
241
