LangMichael
Hi guys,
I´m configuring a AB Guarlogix with Safetypartner and the 1756 DeviceNet-Scanner!
Using:
- 3x 1791DS-IB8X
- 1x 1791DS-IB16
- RSLogix 5000
When I go to "Controller Tags", the Input values of the modules are presented corret.
But I can´t set any Output, or force them. (I can, but the real output won´t get high)
After some reading, I found out, that this might be, because the scanner is in Idle mode and there, Outputs are not controlled.
My problem now is: If i set Local:3:O.CommandRegister.Run nothing happens. But the scanner reacts, for example if I set ....Register.Reset!
Has anybody an idea, what the problem could be?
I would be very thankfull for any information!!
thanks for the help
Using:
- 3x 1791DS-IB8X
- 1x 1791DS-IB16
- RSLogix 5000
thanks for the help
