AB Compact LOGIX 1768-L43 to Balluff IO-Link
reidyj
Aug 2012
Limerick
Hi Guys,
On work experience from college at the moment and this site has been helping me a lot! But I'm totally stumped on this one and need to ask a question!
I have a AB Compact LOGIX 1768-L43.
IT has a 1768 E-Web/A Ethernet card in it.
I have a Balluff BNI EIP-502-105-Z015 Io-link card which communicates over ethernet.
So as far as I can work out the procedure for adding it to Rs Logix goes as follow's:
When offline go to
-I/O configuration
-Right click my ethernet card
-"Add Module"
and add a generic ethernet device and so on.
where my problem lies is that "add new module" is greyed out, even when offline.
As part of my investigation I added the standard ip card 1768 ENBT/A, the option is not greyed out in that case.
So, is what I'm trying to do not compatable with the E-Web card or am I missing the point somewhere. I'm told some one got this to work here before with the same set up...
Any ideas, I hope I've given enough info, if theres anything missing just ask!
Cheers
J
The -EWEB modules are a "web services" Ethernet module, which allows unscheduled messaging as well as web server, e-mail, and open sockets Ethernet services.
To make room for those extra services, the cyclic I/O exchange feature was removed from the module.
The -ENBT modules are the ordinary I/O and controller messaging modules, which is why the I/O connection is available for that module.
If you really want to appear clever, we might be able to make the -EWEB work using explicit messaging. Is this a test of skill and wit, or a real industrial application ?
Hi Ken,
Thanks for the reply, I had suspected there was something different in the modules alright. I tried with a control logix with a standard ethernet card with no problem after I had posted here as a sanity check.
Its not directly for an industrial application, It was more of a feasability study to see if the Balluff was up to the task for a job we're working on.
I would be interested in a rough idea of the approach using explicit messaging.
Cheers
James
I have a question concerning network connectivity to a Compact Logix 5343 1768-L43 processor. Some background information: 1) The 1768 PLC...
1,661
Hi I dont know if anybody out there can help.Itried to install firmware to ab 1768 L43 processor using serial port and rs linx df1 driver.all was...
9,215
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
98
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
112
I've blown the Output Transistor on the Output Card of a Compact Logix 1769-L24ER-QBFC1B It says J378. Does anyone know the replacement part...
205
