AB ControlLogix IOs
Hi
Not a easy question to answer
Is it rack type I/o , remote plc I/o is it s7 200, s7 300, s7 400,s7 1200,
Or the new 1500 io, digital , analogue etc.
Your question will need more information if you would like it answered
Donnchadh
Which ControlLogix platform do wish to compare? Is there a fieldbus?
More information gives you a better answer.
Hi
You could use any make you like on profibus as long as you have the gsd file.
To you want to use Siemens or wago or Festo etc.
Donnchadh
82
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
103
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
231
Hello, My associate and I are trying to sync up two ControlLogix racks (7-slot chassis) with identical modules. We are able to see the secondary...
214
Trying to setup a message read via Ethernet. I have the path setup as 1, 1, 2, 192.168.66.10 I get an error code 1, ext err 315. I am beating...
253
