AB Dataliner DL5 replacement?
Omni
Jun 2007
Brisbane
A batching control system with multiple 2-line DL5 dataliners has a couple of faulty DL5 displays. All displays are connected to the same 16 lines for binary input and are separately keyed (PD terminal) via a Siemens Simatic 545 PLC. DL5s are no longer commercially available. This system is planned for replacement in the next few years but if there is an economically viable way of replacing these (rather small) displays, advice would be greatly appreciated.
Sign
Try these. We are now installing these Via wireless in the mill. Comes with software. If you use variable data in the signs you have to purchase the Active X Windows Control and use their examples of VB Scripts to get your signs working. Im not sure if there is a supplier "down under". http://www.alpha-american.com/
Hello Everyone. I have a Dataliner DL50 that I am using for a project here at work. As of now I have two DL40's. One on each line. Those are...
1,524
I have 2 Dataliner DL50 displays (2706-F11J) that are driven from an AB 5/03 PLC. Its old school but works very well for being in service for ~15...
2,759
I have a Dataliner 30 that someone decided to get wet and fried it. As far as I can tell the DL30 gets its info from a TTL output card from PLC5...
1,471
I have read the User and Programming Manual, and Im still not able to figure a few things out. Is it possible to upload messages from a DL20 and...
1,546
Greetings to all ! Does anyone know where I might get my hands on Development DOS based software for an Allen Bradley Dataliner 40 ?
6,248
