Ab Pb 32/ Pv550 Topic
PERSPOLIS
Jun 2002
ontario
295
HI
I have had different problem: I did upload panel view 550 program without any error and saved it but when open the off line program I always get error and unable to open it to view. If anybody has dealt with problem before and resolved it please let me know.
I have seen this before a number of times. I don't know why it happens but the work-around I use is to use the option "Upload to a temporary file" and open in PanelBuilder instead of saving directly to a file. Then when it is open I can save it as a PB32 file and open it from then on.
Version mismatch? What version do you have? If yours is older then the one that created it, you might have this problem. What is the error and can you post the file?
These are the messages I get:
1- file .........is an old version it will take twice for loading under new version of panel builder perfrorm save as *.pba press OK.
2- open status window for file conversion is visible but nothing happens and at the same time another window is opened with this message:
unable to load file. Not a panel builder 32 file or file is corrupted or disk space is low. once OK is clicked then pb is closed.
Yep, that was the message I was getting. See the picture below. Make sure to select "Upload Application to Temporary File and Open in PanelBuilder32". Then when you save it make sure to "Save as" a PanelBuilder32 file. Since you uploaded to a temporary file I believe it defaults to wanting to save as a PVA. Again, refer to the picture below. Hope this helps.
Hmm.. had a simular problem, I upgraded to XP & cannot get PB32 to upload & open files from panelveiw, however if I uploaded on win98 on another laptop with same PB32 version it works?.
Is there a way to add a stop to the attached program? I want to stop it after the first rinse so the operator would have to push a button for it...
1,229
I'm trying to connect a PV550 (2711-T5A2L) to a 1761-NET-AIC using a 1747-C11 cable (w/RJ45 removed) and the Phoenix connector. Can someone tell...
2,672
We have an old machine that has been mothballed since early 2018 and management are looking at more work for it in 2022. The system runs on an SLC...
2,881
Trying to write a program for a PV550 (2711-T5A16L1, Ser. B, Rev. E, FRN 4.46) to test the touchscreen. I wrote a program with 16 pages and on...
1,696
Good Morning Folks. Win Xp, PRO, Version 2002, SP3 RSLinx Classic 2.54 Using the AB UIC-485 driver with the 1747-UIC and a 2711-NC13 connected...
1,223
