AB String Displai on a PV
jimtech67
Jun 2002
New Jersey
507
Can I display ST data file values from SLC 500 5/03 on a PV 550. I want to display the data in ST50:1 on the PV and write to the register from a PV (example Product 1).
If I have to use the ascii data registers it seems I can only fit 2 characters in each register. I am trying to have the customer change recipe names with the panel view. It looks like a lot of work. It may not be worth the time and cost to the customer. This change is minor priority on the job.
Unfortunately I do not have access to the hardware to test anything or I would start trying stuff my self
GO JETS
In the Panelview program for the string display tag properties change the -> Format -> String Width - change its value to what length you want.
So if the Tag is A30:0 and the length specified is 16, then the string displays of panelview displays strings from A30:0 to A30:15.
Also in the tag 'Data Type' properties choose Character Array.
The Above display will displays PLC's Data File A30(Ascii) strings stored in A30:0 to A30:15.
Good Luck
_________________
PV and ST
The PV does support ST data types.
The only "trick" is that the address is entered as ST50:1.1.
The ".1" allows the PV to start accessing the string starting with the text data. If you just enter ST50:1, you'll start with the .LEN part of the string, which is not what you want.
All, I am trying to reset timers when a Work Order change occurs. The Work Order comes in as a string and I am comparing it to a tag...
66
Hello, I am using studio 5000 pro and am trying to figure out the structured text. Here's my scenario: An operator scans a barcode, the barcode...
280
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
184
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
444
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
146
