AD ECOM problem
BoxerBrats
Jan 2005
Chico California
187
OK been having problem with trying network 2 AD PLCs and a touch screen. When using NetEdit3 it sees all the ECOM cards, and ethernet card on touch screen. When using EZ Touch software it sees all nodes, and recogonizes the ECOM cards, but just doesnt communicate.
When trying to go into the 205 PLC direct would NOT connect... then connected after numourus tries, but would give me a Non-Fatal error. Then goes to Fatal Error. When we removed the ECOM from the rack, It saw the K-Sequence instantly connected with no problems, and no errors. We put the ECOM card back, and errors were back.
What I am wondering is it possible that the ECOM being bad could it create connections problems between the touch screen, and the other PLC?
You are not putting the ECOM into slot 0 are you? On the 205 series, the only modules that can go in slot 0 are DIgital and Analog I/O and the D2-CTRINT.
Hi there Guys, My first post on this Forum ! I have a Set-up for sending SMS from PLC to Modem - MICROLOGIX 1100 PLC - WAVECOM FASTRACK...
3,565
Hi Forum. Background: Been using Directsoft32 Ver.4 on a laptop with XP to program DL-06 PLCs with the ECOM module as my link to download the...
2,068
Hi, I used to use my Lenze EMF2102IBCV001 LECOM a/B module to connect to many Lenze 9300 series servo drives. Now I would like to connect to Lenze...
512
Hello everyone, I got stuck on Communication with DL06/DL260 (H0_ECOM or ECOM100) through Modbus TCP. To make it simple I only read holding...
1,447
Hi everyone, Anyone know how to fix Lenze lecom A/B drive i get "LU Message" :huh:? Thank you all.
4,256
