Add on instruction - Tag visibility
PreLC
Apr 2019
Mars
587
Hello PLCS.Net!
I'm recently making an AOI in Logix Designer V20~ which validates a string-family tag based on certain criteria.
The AOI Takes the string as one of the parameters, the validation part is working fine, but it doesn't display the actual string's value.
Is there a way to make this happen? Please let me know.
Thanks!
-PreLC:skuller:đź’€.
Hello PLCS.Net!
Thanks!
Is the parameter showing up on the faceplate of the instruction? Just trying to figure out if you mean that it shows it in the faceplate but not the value, or if the parameter isn't visible without hitting the ... button.
String values won't display in the AOI block on ladder logic rung. I've run into same issue and just put an EQU instruction before the AOI with the desired string tag to monitor in the rung
It is showing up in the faceplate without expanding it. But not the value of it.
Thanks!
-PreLC
Hey all, I have Add on instruction for poweflex drives in rslogix 5000. I wish to add a new tags in the AOI. What i know is that , I cannot be...
1,914
Dear all, Does anybody know if it is possible to read the add-on instruction, major and minor revision attributes as a Tag? (as entered in the...
1,614
hello every one i want to know in add on instruction can i use external tag by alias tag in version17 i read but founded that it is in the...
3,135
hey good afternoon ! I have a simple question, I need to import an Add on instruction to a controller that is in operation and cannot stop. Is it...
301
please can someone help me how do i add status bits to the add on instruction in studio 5000 thank you
1,481
