Adding a new routine Control Logix
bfranklin
Sep 2012
Alberta
125
I am farely new to the whole automation world>
I have a Control Logix program and would like to add a new routine but that option is greyed out. I am able to view the routine and any other routine just not add a new routine??
If the controller key switch is in the run position that would prevent any changes to the logic. That is one of a number of possible reasons.
OG
What version of RSLogix 5000 are you using? What type of program are you trying to edit?
Some versions of RSL5000 do not permit editing in certain circumstances.
Sorry. I should have been more precise. What edition of RSL5000? Starter, Professional, etc.
Also, in RSL5000, ladder logic is the type of subroutine which is added under the Program which is under the Task.
So, you are attempting to add a subroutine under what type of program?
I figured it out.
Program must of had a glitch, just had to shutdown RSL and fire it back up and now it works.
Thanks!
Hello Experts, Will there be any issue if i add a routine Online in Run Mode?? Will it require a download? I don't have a live PLC for simulation...
3,493
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
67
Hello, Im building project with 1756-L82ES controller and 1756-IB16S card but i cant find it when trying to add the card to IO configuration...
144
Hello, I have a pair of redundant 1756-L71 controllers rev 24. These controllers currently have produced and consumed tag interfaces to 3 other...
176
