Adding an another HMI
JeffB
Apr 2002
NW Arkansas
79
Hi Guys,
I've got a project where I have to add an additional Magellis XBT touch screen to an exisiting Unitelway network.
Can two touch screens on the same network address the same variables in a telmechanique P57302 PLC?
I really appreciate any help.
Jeff
Hi Jeff
You can not connect a 2nd Magelis in one Unitelway network. In my last project I’m using a TCP/IP network to connect a Premium PLC to one PC and one Magelis. This way, I believe you can connect the two Magelis. I can check Monday and let you know.
João
Jeff
I tried with one Magelis XBT-F024110 connected to the TER port of a TSX 57 2623 (Unitelway) and a XBT-F024610 connected to the Ethernet port thru a HUB. I had no problem wrinting and reading the same variable in both Magelis.
I don't know if there is another way of doing this.
You can download the complete Magelis manual at www.modicon.com
Hope this helps
João
We have a new piece of equipment being installed soon that will need to pass a few handshaking bits between it and our main conveyor plc. I will...
3,333
Hi all I’m looking at adding a RFID card reader to comfort panel pro , how do you set the rfid up can you connect to existing users and password...
47
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
114
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
91
Hello, Im building project with 1756-L82ES controller and 1756-IB16S card but i cant find it when trying to add the card to IO configuration...
166
