Advanced HMI Now Works with TwinCAT
ndzied1 said:
Will this work with any CoDeSys based PLC or just TwinCAT?
I've only worked with the Beckhoff TwinCAT extensions to CodeSys, so I'm not sure if the protocols are the same. This driver is based on the ADS driver that is downloaded from the Beckhoff website.
Maybe there are some experts that know if the Beckhoff ADS/AMS communication model is really the CodeSys software or whether Beckhoff developed it especially for TwinCAT.
As for the OPC drivers, I'm sure that is going to be a ways out. I haven't dug deep into it, but my guess is that the specifications are not free.
From Beckhoff documentation:
ADS "Automation Device Specification"
Overview Connectivity and describes a device- and Fieldbus-independent interface. This interface got designed by Beckhoff, and is - including the protocol - in detail documented.
For integration into own applications resp. compilers and tools based on Microsoft Windows Operating systems (NT / Windows 2000 / XP / Vista .. and CE) there are ADS components (ADS-OCX / DLL / NET / ...) available from Beckhoff, free of charge.
The ADS components get installed together with TwinCAT and can be found in the following directory "..\TwinCAT\Ads Api". Additionally, all named components are also available in the free of charge TwinCAT Supplement product "TwinCAT ADS Communication Library" (only exception is the ADS-OCX which belongs to the core components of TwinCAT).
Basic Light Problem with Advanced HMI
Hi Archie,
I recently downloadad your Adv. HMI for testing purposes.
I now have problem with Basic Light Control, you can see in attachement.
Tnx
Not yet sure what is causing it, maybe the program is using a font that is not on your PC.
For a quick fix try this:
1) Right click BasicLight.vb in the Solution Explorer (upper right under the controls folder)
2) Select View Code
3) Find the OnPaint event (will be in the Events section)
4) Add the second line show here:
Code:
[SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Protected[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Overrides[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Sub[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] OnPaint([/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]ByVal[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] e [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] System.Windows.Forms.PaintEventArgs)[/SIZE]
[SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]  If[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] LegendFont [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Is [/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Nothing [/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Then [/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Exit [/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Sub[/COLOR][/SIZE]
[/COLOR][/SIZE][SIZE=2][COLOR=#008000][SIZE=2][COLOR=#008000]  'If _backBuffer Is Nothing Then Exit Sub[/COLOR][/SIZE]
[/COLOR][/SIZE]
Does/can/will AdvancedHMI work with CE6.
It would really be nice if the AdvancedHMI program would work with CE6.( I.E. CompactNet 3.5.) It would be heavily utilized in Beckhoff CE environments.
Thanks a bunch..
Early on I attempted to keep it compatible with the compact framework, but the graphic capabilities were too limited to acheive the quality I wanted.
It could probably be made to work fairly easily with the "basic" components and using the TwinCAT CF driver.
The quality of graphics is awesome. Thanks for the consideration. It was quite easy to combine 2 controls from your AdvancedHMI into one. I just don't know what the compact net 3.5 2008 had over compact net 2.0 and how easy it would be to convert. Perhaps if you could get one control to work with CE others could expand upon it.
The easy part is to figure out what it takes to convert. You can simply add the controls to a new Smart Device (Windows CE) project and see what it doesn't like.
The hard part is implementing or finding alternatives. For example, the System.Drawing.Drawing2D.Matrix object and the transform are used to do scaling and rotation. There is no equivalent in the compact framework, so they would have to be implemented in code. It may sound easy at first, but to get the equivalent quality of graphic manipulation done by the .NET framework is not so easy.
The .NET framework is now open source, so if someone was really ambitious, they could duplicate it exactly. The nice part would be that if the Matrix was implemented in the compact framework, then the rest of the project conversion would be easy.
Hi Archie,
First excuse my poor english!
I downloaded AdvancedHMI, it looks very good.
now i have some trouble with the sample i saw in youtube video, need help .
I have this message on the DigitalPanelMeter1 control : "UNABLE TO GET ADDRESS INF" and nothing happen, i don't now what is th problem.
I’m new to plc programming and very new to HMIs. So this is what I have done so far: I bought a micrologix 1100, I used bootP to set the up...
17
1,740
So I installed advanced hmi and grabbed an ethernet cable. I have the click C0-12DRE-1-D PLC. I installed the advanced hmi and added the...
2,135
Do I use the ethernet port on the click plc to connect it to my computer. Will advancedhmi work properly? Am I able to start data logging into a...
957
Having a hard time getting the data received when using BeginReadMultiple. Not the most familiar with the ClxDriver and EthernetIPforCLXCom()...
2,362
I am in search of a non-PC based, non-SCADA based HMI and software that allows the ability to dynamically draw graphical objects on the screen to...
5,097
