Advantech WebOp 3070T
Lemming
Oct 2004
PalmerstonNorth
332
Hi all
have been given an Advantech WOP-3070T HMI to evaluate. On power up, the device boots straight into Win CE desktop. Had a browse through the program manager, but nothing looking like a runtime package is installed??
Anyone used these and advise what it should look like on power up ??
I’m using Movicon Windows CE, the runtime/license all are inside the HMI,
If I want use Runtime, I need to purchase RT Software/License (e.g. Dongle)
Then install on PC/Desktop Workstation.
When booting the HMI Windows CE its boots like others Windows and the system will check the software/hardware license.
If everything ok the system will look the startup-page for autoboot the HMI program or we need to go external drive to start the HMI program.
From the development software help, seems an "Advantech" HMI runtime should be installed... Nothing in the help depicts the CE desktop... I'll hassle the distributor tomorrow.
After installing the WebOP designer there will be a folder containing "PanelExpress for WinCE Setup Note.doc". That doc contains the setup directions.
Thanks for the heads up, is working fine... have spent 5 minutes on it and is talking nicely to a micro1100. Looks to be fairly powerful in terms of features. Any fishhooks you are aware of with It??
Well, I've not had any seat time with it. It was passed around the office and I've seen it powered on on somebodies desk but that is about it.
(I had to inquire to get the info about the note, I didn't know the answer either at the time)
I didn't end up using.. Only had the sample sent to evaluate, and is so long ago barely remember.. have ended up using the affordable LS exp40 panels as default..
Sorry cant help more..
Hello, Has anyone ever tried to get comms working between an Advantech WebOP-2070T panel and an Automation Direct Productivity 2000 PLC? I...
1,921
Good people of PLCs.net, I am currently working with an HMI that is advantech 1250H, that communicates with a 1769 Compact logix and Currently...
71
Hi, I have an older Kohler Generator/ATS controller that has a Schneider Electric (Modicon) Momentum PLC and has a Advantech HMI. I assume this...
721
German and English Grüß euch, ich hab im Forum zum Thema Panel download leider keinen Beitrag gefunden und möchte euch folgendes fragen: Ich...
1,121
I am trying to read Schneider power meter PM2120 data using M221 plc.Power meter Pm2120 is connected to serial port of modbus/tcp gateway...
1,529
