Alleb bredely 1769 l32e
nomanarif
Oct 2014
karachi
HI everyone
i was trying to upload a program from AB 1769 L32E... But it has given my a firmware version issue.. i am using rslogix v19,so i hve upgraded its firmware version to 17.12 from serial cable but in the middle because of power failure i have to redo it... so i have done soo... after that i have realized that i hve to upgrade it to version 19.xx, so i hve upgraded it but in the middle it was giving some error after 2 of 3 etc.... after that i hve checked the firmware verions it was changed to 19.11
but my plc was showing( there is no program in controller to upload) that it has no program now and HMI is also not connecting as before, previosuly it has program and was working correctly
kindly help
There is no way to recover it unless you have a copy somewhere else. A firmware update clears everything from the cpu.
Well, if somebody could use NSA IT(?) guys, there might just be a theoretical chanche to restore something.
There are commercial service providers to recover deleted files etc. as well but I dont even want to guess the cost
thanks
thanks guys for the reply and help now i have to be carefull for the next... actually i m not getting any way to upload the program without firmware upgradation...
i will not refer AB plcs to my client now.... too many problems in uploading a simple program
"Me thinks the problem is not with the PLC brand"
Couldn't agree more. The big warning message that comes up warning you that everything will be deleted if you flash the firmware should have been a clue and if you haven't got an up to date copy of the program why would you click on OK?
Hello, i am attempting to set up a new AB IO Link Master. Cat No 1732-8IOLM12R with a CLX L74 v32 though a EN2TR. I set the IP via Boot/P...
607
Dear All, can anyone confirm me that if I replace 2094-BM01-S module of kinetix 6000 then would it need to reprogram the device or it will be...
2,521
We had a Processor Failure yesterday. Opened a new in the box Processor, and could not get BootP to work with it. After a few hours of trying...
218
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
111
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
138
