Allen Bradley Guard PLC and RS Logix 5000
Redland Brick
Mar 2005
24
Hi Folks ,
I have a question. Did any of you ever have any problems with
going online with a Guard PLC with RS Logix 5000 v 14.1.
The problem is that we get a major fault and it deletes the program.
I believe the fault is a power up fault.This only happens when
we try to go online.
These are the versions and setup that we have:
Processor Firmware 14.32
RS Linx 2.43.01.23 (CPR 6 )
RS Logix 5000 14.1
Windows XP
We have a company here from Europe that installed the machinery
and they do not not have any problems. The only differences
I see is they have RS Linx 2.50.00.20 and Windows 2000.
Do you guys have any ideas,
First, lets get terminology correct:
You are talking about GuardLogix PLC that is ControlLogix based and uses RSLogix 5000 ver 14
Guard PLC is a separate product thet uses RSlogix Guard Plus software to program.
With Guardlogix what firmware do you have? Check it in RSlinx.
If it is not 14.33, you need to upgrade it to 14.33.
Edit: I see now your FW is 14.32 - upgrade it to 14.33.
See release notes http://support.rockwellautomation.com/controlflash/FirmwareFiles/1756RN020BENE.pdf
You have a limited-release very special product version into which Rockwell put enormous amounts of time and money for development and support. This is a machine safety controller, not some toy that you should be casting about on the Internet for advice on.
Call. Rockwell. Technical. Support.
Any one give solution for this fault. We are using AB Gaurd logix controller(5573s), resent days we are facing major fault in controller...
80
Hi all, I’ve been asked about a project at work but given very little info. I’m somewhat experienced with Allen Bradley but far from an expert...
1,895
Good Morning , A co-worker installed a Allen Bradley MatGuard this weekend . They were not able to get it to work . He was using a MatGuard...
1,120
Hey Guys, I need help with interfacing a datalogic matrix 210 barcode reader to an Allen Bradley Compact Guard Logix L43S plc. Does anyone have...
2,092
Hi, Have anyone try a hand on AB GuardPLC? I'm from Malaysia and there is no proj. reference for this new GuardPLC. I'm actually doing a...
4,623
