Allen Bradley low temperature HMI
rQx
Oct 2010
Trelleborg
1,051
We currently use PanelView plus 6 HMI. Is there anything from Allen Bradley in the same price range but that has a low temperature rating? I know Siemens have a low temperature version of their comfort panels that go down to -30. But I struggle to find an Allen Bradley HMI with similar specs.
/Tim
Thanks alot, so based on this information there isn't an Allen Bradley HMI that can withstand low temperatures. We already have an inspection window over the HMI for protection but it's still 0 degrees limit. If we need lower I guess we switch over to Siemens
/Tim
As another option, Red Lion Graphite HMI's are rated -20C for indoor models and -30C for outdoor models.
Thanks for the tips. We use either Allen Bradley or Siemens and do not mix brand HMI/PLC , but always good to know what is on the market
Good Evening , I have a Guardmaster Safety Relay I have 14 vdc on S12 (Safety Input for IN1 Channel 1) and on S22 (Safety Input for IN1...
3,561
Hello, Does anyone here have experience working with the a-b micro810 with the lcd display. We have churned out a workable program but the inbuilt...
2,469
Hallo Everybody, Did anybody from you had a sample how to do pump control with flow sensor ??? I only did temperature control with pide yet...
4,578
Can someone provide me an example of message configuration from Allen-Bradley PLC-5 to an Omni 3000/6000 Flow computer through the 1785-KE module?
3,990
365
