Analog Inputs to ELC
btroxell
Jul 2008
Kokomo, IN
I have two sensors that output from 0 to 5 VDC.
How do I process these input signals in an Eaton Logic Controller ELC-PV28. I need to take the voltage and multiply by 20. This number will then be used to determine if a coil turns on.
I am very new to PLCs so any help is greatly appreciated.
I am converting a SLC 500 to a Compact Logix. I plan on using a Compact Logix 5380 with conversion Kit. The problem is that the analog input cards...
151
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
108
Hello I need to message read the entire 16 channel raw analog inputs from a 1769-L33ER Compact Logic controller to another 1769-L33ER Compact...
249
I have a SLC500 5/05 and we have an alarm setup to monitor the status of the Analog Inputs we have wired to a 1746-NI8. We are using 5 of the...
2,818
Hi, I'm curious if anyone has made a master sheet or cheat sheet for all allen bradley card's analog inputs/outputs? As much fun as it is to...
1,590
