Analogue outs
jeepmadmike
Mar 2005
29
Hi all
Now im a bit of a novice in the PLC world and it would be very useful if anyone has some advice on programming analogue o/p on a AB micrologic 1200 all a want is to have a few analogue output set points which i can call from the program.
Thanks for any help
i'm using the analogue o/p for speed control of a motor via an inverter i want to have 6 set speeds for the motor which i can address from different points in the ladder.
set the config setting in the aanlog card
use SCP inst to convert engg value to counts
Input (some integer or float Address)
Input min 0 Hz ---- Engg min
input max 50 (or) 60 hz ------ Engg max
output min 0 (or) 6242 ---- 0 mA (or) 4 mA
output max 31208 ---- 20 mA
enter your output Address O:1.0 (analog card in slot 1 ch0)
if you enter some hz in Input corresponding mA is produced in the output
ihope this will help you
regards
praveen
You need to set up an array, then get the preset data from the position in the array.
I haven't used AB for awhile and don't have the software to quickly pop up an example, I'm sure one of the others will help you out.
(NOTE: the USA will be waking soon :nodi: )
409
Dear community, I am trying to find a tool for Allen-Bradley PLCs similar to SiVArch for Siemens PLCs to automatically generate faceplates and...
110
I am using Mitsubishi PLC :FX3g and downloaded the program in it. When I connect Mitsubihi FX2N-4DA expansion module, it lost its communication...
270
Hi All, I am working on a small PLC system having Compact Logix LE33 PLC having only two IF4 card. Some of these channels are used for 4 - 20...
1,169
Hello guys I am just wondering do I need to set up each channel configuration, including enabling the channel , ranging … if I have already...
2,026
