Anyone experienced using a larger (11kW,15hp) VFD 3 phase using only single phase in?
Sorry guys but I'm not familiar with yours voltages levels, so I use my - EU standard.
Maybe I don't understand you correctly but:
It's not possible to feed motor 3x400V form inverter supply with 1ph (230V). But when you have motor 3x400V star, then you can connect it to delta=3x230V and supply from 1ph by inverter (derating needed because you have only 1ph).
THe setup that is being discussed is a 3 phase VFD built for 480 3 phase line.
THE question is -- can it be supplied with 480 single phase to the VFD.
THe 480 was derived by 2:1 stepup transformer fed with 240 single phase.
This setup would work as DickDV said.
Dan Bentler
I do not understand the meaning of "MCS" and "MCR" in the Instruction List of GE series 1 The folowing is the sample of Instruction List . . 0304...
2,501
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
166
this a program to send data to barcode printer I want to integrate a new printer in a new machine and i wanted to adapt the old prgram on it but I...
206
I received an email from a student with the following code attached. This is supposed to control a floodgate system, and supposed to be written...
23
864
