Anyone have experience with old Bosch servo drives?
JKS
Dec 2014
Portsmouth, NH
56
Specifically Sm10/20-TC.
I have a customer that has a setup running a crosslapper, and this module runs the outfeed apron. They were having a lot of stopping issues where we diagnosed it back to the module going to hell, so they found a used one and I popped it in for them.
Did the best I could at ensuring everything was identical to the one we replaced, but they tell me that they're having some odd intermittent problems: doesn't start up and stop right away; speed seems to vary at times, causing the looms to do some wonky things; stuff like that.
Of course, every time I'm here, it either runs Ok or they can't get the line to start up for other reasons (material, mechanical failure, etc).
They have decent documentation - more than I can find on the web, actually - but it reads as if someone with aspergers wrote it, and I'm just not smart enough to fill in what they assume I should already know.
I've tried tuning it slightly, with the P and I pots as well as the Offset adjustment, but I can't tell if it did anything really or not. Hell, I don't even know if I'm doing it correctly.
So, long way around to ask if anyone has any experience with these and a good procedure to tune it in better. If nothing else, someone with some knowledge that I can pose questions to.
Thanks in advance for any help - it's greatly appreciated!!
- Jeff
Hi all, I am experienced with Rockwell by have recently encountered a Bosch PLC. It’s an IndraControls XM21 V14. I installed the software and...
791
Hi all, Client called saying that the turbidity readout on the HMI is 0.0000 but on the local readout, it shows an actual value. Sure enough...
5,461
Hi We are looking to implement some label checkers on some production lines. We want to check bar codes and best before dates. Just looking to...
3,445
Hello, I'm a big fan of the HART potential in getting multivariable off of complex instruments like flowmeters and some pressure sensors, but...
2,443
Hey guys, I'm working on a proposal for a client, and long story short I need to suggest a new master PLC for polling existing RTU sites that are...
23
9,869
