Archestra could not resolve reference
Adam Bullen
May 2012
Taupo
Hi Guys;
I am getting this error when I try to reference anything in my template with a different reference then the name of the IO attribute.
I am talking via the ABCIP driver to a ControlLogix PLC. This is an existing plant with an existing InTouch application that we are going to migrate to Archestra Graphics. I am working on a test platform; one issue I have is that a reference with a different IO name doesn't work.
e.g. Archestra won't resolve attribute "MotorAlarm" as <iodevice>.$Motor.InAlarm since "InAlarm" is a reserved field; this is an issue for me. There are a few motors in the plant where an alarm not in the motor UDDT will cause the motor to be "InAlarm" this is handled in the PLC.
I decided to test this further we have a basic AlarmStd UDDT with Alarm; Ack; Delay and SP.
Archestra will resolve just fine if the attribute is called Delay.ACC -> "<IOdevice>.$AlarmStd.Delay.ACC"; but if I change the name to Elapsed with the same IO path it doesn't work any more.
Can someone help me out here as to why this is.
Using: Wonderware System Plataform 3.0 SP2; Intouch 10 SP2. I used the Archestra to create objects using a script to automatically assign object...
8,235
So I made some changes to our plants WindowMaker application and I'm having trouble deploying the update to the live runtime. From the deployment...
133
Dear All, We are designing a solution with 1756-L74 and Archestra. We need to use SOE to show on HMI. Please mention any solution if someone did...
137
So I'm trying to enable history for a tag that is being used to display PPH on InTouch. I was able to locate the tagPath by finding the display...
699
Got myself into a bit of a jam this AM. Somehow the graphic editor hiccupped and when I went back into my graphic, everything was gone. I...
1,083
