Archestra ShowGraphic script trigger
Snap25
Dec 2014
Michigan
237
I'm having issues getting the "while left/key down" or "while right/key down" triggers to work. I used the same script with the standard "left click/down" trigger to show instances with no issue.
Am I misinterpreted what the "while X/Key down" trigger w/ a set ms value means?
I want to hold a tab down for 5000 ms before it shows the graphic I'm calling for.
There has to be a more efficient way of implementing this type of button characteristics in ArchestrA?
The only way I can think of doing it would be to have the button act as a direct button and use a While true condition script to compare a 5 second timer to the $second tag?
Are holding button pushbuttons for x amount of seconds not common practice enough for wonderware not to implement it as an option?
I migrated to a WSP2023 application. Now when I open a HMI object (for example a valve or motor) the popup is first correctly show as defined ...
30
So I made some changes to our plants WindowMaker application and I'm having trouble deploying the update to the live runtime. From the deployment...
156
Dear All, We are designing a solution with 1756-L74 and Archestra. We need to use SOE to show on HMI. Please mention any solution if someone did...
157
So I'm trying to enable history for a tag that is being used to display PPH on InTouch. I was able to locate the tagPath by finding the display...
735
Got myself into a bit of a jam this AM. Somehow the graphic editor hiccupped and when I went back into my graphic, everything was gone. I...
1,115
