archestra
RY_Guthrie
Nov 2011
Las vegas, NV
263
when I try to start up archestra on my laptop I get the message unable to connect to galaxy check logger for details. It says in the logger componenet "wwpackmanager" wonderware ssc- version 7,0,100,1 (3:1,1)(2:44,1) (3:5,0,97)
I was so sorry to hear about your difficulties. I wonder what could be causing that? Havee you installed new programs on your laptop recently?
Many of the Log messages i don't understand as it has to do with processes in the background. I would contact Wonderware Support with this issue. They would have a comprehensive database of tracked issues that might be similar to your issue.
Rheinhardt
So I made some changes to our plants WindowMaker application and I'm having trouble deploying the update to the live runtime. From the deployment...
144
Dear All, We are designing a solution with 1756-L74 and Archestra. We need to use SOE to show on HMI. Please mention any solution if someone did...
144
So I'm trying to enable history for a tag that is being used to display PPH on InTouch. I was able to locate the tagPath by finding the display...
708
Got myself into a bit of a jam this AM. Somehow the graphic editor hiccupped and when I went back into my graphic, everything was gone. I...
1,095
It's a while since I had used this that I forget where the setting to enable/disable object security is. There are some devices (pumps/valves)...
863
