You might be using RSLogix 500 Micro, which doesn't support the SLC Modular controllers. I'll save the project as a MicroLogix (edit: Thanks Bob !)
The Termination Characters and Append Characters perform different functions.
Termination 1 and Termination 2 are compared to incoming ASCII strings to determine where the end of a Line is. The value of "\ff" in the second field means "ignore".
So the default settings mean "when the buffer sees a Carriage Return in the incoming data stream, it considers that the end of a Line". When you use the ASCII Read Line (ARL) instruction, you get the characters up to the Carriage Return.
Append 1 and Append 2 are the characters that are sent out after the String characters when you use the ASCII Write with Append (AWA) instruction. The default values are \d and \a, which are Carriage Return and Line Feed.
These characters are not sent when you use the ASCII Write (AWT) instruction.
Why does RSLogix 500 use different default Termination and Append characters ? Why are the characters sometimes displayed in lowercase hex, sometimes in uppercase hex, and sometimes as control characters ?
It's a mystery. They're just that way.
