ASI slave diagnostics
Werner
Apr 2005
IJsselstein
336
We use a DP/AS-Interface link 20E. This block converts the ASI network to profibus I/O. I need something to indicate an ASI slave is not working. On the Siemens site I found some information about FB125/FC125? Does anybody know how to incorperate this into the S7 software?
My goal is to make a message on the HMI when ASI slaves are in error. On the site below I found exactly what I need. Unfortunately the download sites are not working.
http://www.sea.siemens.com/automat/product/net/pfb/diag/aufb125.html
Can anybody help me?
Hi Werner,
As far as i know there is only FC7 (ASI3422) to use with CP342-2/CP343-2 to indicate slave condition. You can get it from siemens. Basically there is a send and recieve area,ok,nok and status code. i send 19hex in the send area (Read total configuration)
and then recieve the slave configuration to a DB.
We are in the process of replacing Link 20's with CP's due to reliabilty issues, Even link 20E i find a pain in the A**e to set up.
HTH
Steve
As for FB125,FC125 Jesper and Roy have both posted threads about this.
Hi Werner,
Had a thought and checked an old backup disc, FB125 hopefully attached. I have another project with different HMI's using FB125, But you'll have to give me your email as it's quite big!
Steve
Hi all, I am new to the whole As-i and S7 world. I added a 3RK1400-1DQ00-0AA3 41/40 Slave and configured it as slave 2 with hand held...
1,535
Hi, I want to know how to read and write to asi safe slave in Microwin. When the input is activated, in the program the contact begin switching ON...
2,346
we are using S7 300 plc and CP 343, But i don't know how to assign the ifm slave module in asi network
4,549
It is possible at all? I have an issue almost in accuracy same that I have found in official forum Siemens: oshaman wrote: "I have recently...
5,342
I want wnt to know about addressing of ASI slave module. If I enter addressing in slave configuration of ASI Master, the addresses it tatakes...
4,923
