Ask: HMI black screen, Red Lion, Crimson 3.0
Knight41
Apr 2018
Indonesia
Hai All
Anyone help me to solve this problem.
1. Black screen on display, after booting.
2. Error- unable to open communications port
3. Error- the device does not contain an uploadable image
4. Setting in pic 4 is corret but stil error for no 2 n 3.
Just like this www.plctalk.net/qanda/showthread.php?t=94038
But still cannot download or upload
Greetings know and thanks if anyone helps.
Do you see anything during boot? If not, the unit may have a bad backlight display.
Does it beep on power up?
Are you sure that your PC network settings are a good match for the HMI? If the HMI has no application installed, use a USB cable to update it and ensure that you have the file set up to support TCP download... If you can zip and attach your cd3 file, we can look deeper at the details.
What do you mean beeb ? Power on normaly
Yes im sure network is good match.
Ok i try with usb cable.
this pic before black screen, after that is black scren but power still on.
Okay, so it's not the backlight. Can you zip and attach your cd3 file? I have had problems when I was doing a startup program using inaccessible device tags or when I had circular reference errors. Looking at the cd3 file would help.
I try with usb..its same the problem no 3, so i can't download file or extract file..
How to download n upload from HMI ?
I try this one http://www.plctalk.net/qanda/showthread.php?t=94038
But still can not download file.
Hi guys I am hoping you can help me. I want to use an Allen Bradley HMI and PLC to record information every time a Cask is filled to an SD drive...
3,243
So in order for the HMI to what you want it to do everything that the HMI does has to be entered into the PLC program?
18
6,173
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
1,268
We are to develop a first application in Codesys. It will contain motion (Softmotion) with drives on Ethercat (CSP mode). Off course there will be...
966
Hi. Rockwell learning curve 132-1b. I was having trouble to change IP address on a EN2TR. Finally found out that I need to change the IP...
913
