B&R and tcp socket
valer85
Jul 2023
italy
Hi Everybody,
newbie here with PLCs, using a B&R plc.
I'm playing with a printer and its tcp socket communication.
Connection works fine if there are no errors, I followed the example, so tcpOpen, tcpClient, then send something and close.
If, for any reason, the connection is lost (cable disconnected for example), the tcpclient connection is stuck forever in ERR_FUB_BUSY state, and even when I connect the cable back, it's impossible to start a new connection. The only solution is to restart the plc.
I tried also with an external socket tester and it works perfectly fine.
What I'm missing? It's unable to correctly close the socket if the connection is lost?
Code:
    CASE ClientTCP.Step OF
         0: (* Open Ethernet Interface *)
            IF test_tcp OR start_send_label OR start_send_label_ricetta THEN
                TcpOpen_0.enable     := 1;
                TcpOpen_0.pIfAddr     := 0;  (* Which Interface to open *)
                TcpOpen_0.port         := 8000;  (* Port on client side to use *)
                TcpOpen_0.options     := tcpOPT_REUSEADDR;
                TcpOpen_0;
                IF TcpOpen_0.status = 0 THEN  (* TcpOpen successfull *)
                    TON_timeout_comunicaz_tcpip.IN     := TRUE;
                    ClientTCP.Step                     := 10;
                ELSIF TcpOpen_0.status = ERR_FUB_BUSY THEN  (* TcpOpen not finished -> redo *)
                  (* Busy *)
                ELSE  (* Goto Error Step *)
                    ClientTCP.Step     := 100;
                END_IF
            END_IF
        10: (* Connect to the other Station *)
            TcpClient_0.enable         := 1;
            TcpClient_0.ident         := TcpOpen_0.ident;  (* Connection Ident from AsTCP.TCP_Open *)
            TcpClient_0.portserv     := 8000;  (* Port on server side to use *)
            TcpClient_0.pServer     := ADR('172.17.40.20');  (* Server Address *)
            TcpClient_0;
            IF TcpClient_0.status = 0 THEN
                TON_timeout_comunicaz_tcpip.IN     := FALSE;
                ClientTCP.Step     := 20;
            ELSIF TcpClient_0.status = ERR_FUB_BUSY THEN  (* TcpClient not finished -> redo *)
              (* Busy *)
              // timeout for connection
              IF TON_timeout_comunicaz_tcpip.Q THEN
                MpAlarmXSet(gAlarmXCore_Hmi, 'PrinterNetworkError');
                ClientTCP.Step     := 40;
              END_IF
            ELSIF TcpClient_0.status = tcpERR_INVALID THEN  (* Port error -> Close actual connection, and reopen a new one *)
            END_IF
        20: (* Send Data to the Server *)
            TcpSend_0.enable     := 1;
            TcpSend_0.ident     := TcpOpen_0.ident;  (* Connection Ident from AsTCP.TCP_Open *)
            TcpSend_0.pData         := ADR(test_string);  (* Which data to send *)
            TcpSend_0.datalen     := SIZEOF(test_string); (* Lenght of data to send *)
            TcpSend_0.flags     := 0;
            TcpSend_0;
            IF TcpSend_0.status = 0 THEN  (* Data was sent sucessfully -> close socket *)
            ELSIF TcpSend_0.status = ERR_FUB_BUSY THEN  (* TcpSend not finished -> redo *)
              (* Busy *)
              // timeout
              END_IF
            ELSIF (TcpSend_0.status = tcpERR_SENTLEN) OR (TcpSend_0.status = tcpERR_NOT_CONNECTED) THEN (* Connection Lost *)
                label_chunk_ready := FALSE;
            END_IF
        40: (* Close connection *)
            TcpClose_0.enable := 1;
            TcpClose_0.ident := TcpOpen_0.ident;  (* Connection Ident from AsTCP.TCP_Open *)
            TcpClose_0.how := tcpSHUT_RD; //0;
            TcpClose_0;  (* Call the Function*)
            test_tcp := FALSE;
            IF TcpClose_0.status = 0 THEN  (* Close sucessfull *)
                ClientTCP.Step         := 0;
            ELSIF TcpClose_0.status = ERR_FUB_BUSY THEN  (* TcpClose not finished -> redo *)
              (* Busy *)
              IF MpAlarmXCheckReaction    (gAlarmXCore_Hmi, 'PrinterNetworkError_') THEN
              END_IF
            END_IF
       100: (* Here some error Handling has to be implemented *)
    END_CASE
I don't know the programming of a B&R plc, but look if a timeout can be configured to close zombie connections ?
Hi all, I have two questions I am hoping someone might have some information on. 1. I remembered reading somewhere on this forum that you could...
194
Hello, I'm trying to setup a TCP connection from a Compactlogix 5069-L306ER to a TDI checkweigher to receive real-time weight data of the...
325
I would like to communication with application installation in my printer server via TCP port 5450. i.e ., 71.16.40.200:5450 . How can i write...
416
I'm trying to set up a TCP Socket connection between a CompactLogix 1769-L16 and a printer that can receive external data through a TCP socket. I...
3,370
I am at a plant right now that is installing a domino ax350i inkjet printer and it is using tcp socket ascii communication to talk to a compact...
1,499
