bit entry
JRazor
Mar 2006
MN
I am getting the error: The memory module is absent or S:1/10 or S:1/11 is not set.
I have just installed a new memory module, so how do I set S:1/10 or S:1/11?
I have a SLC 5/01 and I am using RSLogix 500.
Any help would be great.
see if this helps ...
See the screenshot of EIP tag list. We are trying to read in a digital input that is hard-wired. It is shown here as I31.1. I believe we cannot...
295
A couple days ago I accidentally toggled an alwasyoff bit. The issue is it was set up as a single OTU on a rung, nothing else, and used as XICs...
229
Hi I have an old panel builder 32 that I’m replacing for a factory talk me hmi . In the plc for the old panel builder there is a coms bit for the...
78
Hello, Haven't been on in a while. I need to generate a bit level pdf of the I/O for RSLogix 500. I can generate a report but it just shows the...
167
I tried researching but I still don't quite get it. As far as I understood, it's used after a function is called in STL and then if the function...
149
