escoplcguy
Hello everyone,
I have beem looking into block measuring and i believe i have found one that could work, but i cant seem to get in contact with my RA sales rep to answer my questions...
i have been looing at the 45MLA measurement light arrays and i wanted to see if anyone here has had any experence with this or something similar?
my questions are, if a block has a slanted top will the sensors see this and be able to measure this?? also our product is fradle and crushable, if a block goes through and has dammages areas will it sense this as well???
for more info......block is being measured for height between 5" to 40" max. some blocks are straigt across others have a slant meaning it starts at 11" and falls to 10" (see sketch) would like to know when taking measurment height of block on both corners to determan if block is a (example) 10" or 10/11".....also like i said some have the corners broken off or holes in the sides, these blocks need to be rejected.
