C++ in Unity Pro
Schtiel
Oct 2006
West
92
Has somebody an experience in programming Modicon PLCs in Unity using C++ language? Is it possible? Is there a SDKC for Unity Pro?
Use Unity EFB Toolkit to develop EFs in C language
Yes Unity provides a SDK-C companion software called EFB toolkit. You'll be able to create some EFs and then enrich the existing libraries of Unity. Of course you can do the same with internal DFB but there is two advantages with developping in C. First, EFs runs faster than DFB so ou reduce scantime. Second, it's of course completely protecting your know-how. Once the EF is created, nobody can open and read what is inside. Main drawback, it's not possible to modify the inputs/outputs and inside program of an EF while used as an instance, whether it's still possible with a DFB.
Hope that helps.
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
196
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
417
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
749
Hello i want to implement a Read_var / Write_var functions to communicate with a modbus tcp device at the moment i use the unity simulator at the...
1,967
Hi, I've exported a PL7 application to the .FEF file succesfully. Imported the .FEF file in my Unity Pro project, but two of the five sections in...
785
