C-MORE EA7 Program Transfer
bluenoser337
Apr 2003
Nova Scotia
391
I have an Automation Direct EA7 that I need to get the program out of to install in an identical terminal. Old unit powers up but serial port is fried. Can't find a manual online but I've been told this can be done without the EA7 software, using a USB drive or CF card. Anyone know? Thanks!
bob1371...perfect!! Mission accomplished using CF card. Thank you !!!!Happy Holidays!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!🍺
Our C-more hmi screen went dark at one point. After power cycling, the screen shows ""no system found in the panel," and the LED status in the...
3,028
A client has an EA7-T8C that is on its last legs. Will the EA9-T8CL install in the same panel cutout or will they need make modifications?
1,620
Has any one connected the Cmore panel to an Omron NJ PLC if so how? I have been reading up on the FINS communication protocol, Seems a bit fuzzy...
2,545
Hope to get some input and suggestions from anyone who has had a similar project. Need to control (very low level) 7 different Altivar 61...
3,304
I understand how the system works: EA7 (Cmore) <--RS232--> DL260 (PLC) <--Ethernet--> LookoutDirect 4 but I have no idea if its possible...
1,840
