Cannot test application on clean install of FactoryTalk ME 8.1
Patient
Jun 2012
Auckland
50
I've just installed FTView Studio ME 8.1 on a new VM. It opens fine, restores and loads a project ok, but when I go to test application it gives me an access denied message and shuts down the test app.
Found this tech note on it. https://rockwellautomation.custhelp.com/app/answers/detail/a_id/34639
The exact symptoms however none of the solutions work.
I can test the default project instant_fizz but when I try opening a backup from my other VM it still gives the access denied message and shuts down.
Tried with version V6.1 and V8 APA to see if it made a difference. None.
- No security set on startup screen
- default user has correct letter ticked (even tried with all letters ticked).
- deleted the hidden folder.
I also get an information message which might be a cause saying no "configuration file was found on RSLinx Enterprise server "project name"".
I tried to re-install RSlinx Enterprise V5.8 when I saw that.
Chat is not available... has anyone else had a similar issue??
I haven't had the same issue, but the error message about no configuration file means to me that the shortcut in RSLinx Enterprise has not been configured.
To run the test application, a valid shortcut must be set in the design tab of RSLinx Enterprise
I am newbie to OPC. I have a new OPC test Client which is running on FMC application supplied in package from Thermo Fished Scientific. The...
14,230
Hello everyone, I am currently working on a project that uses a Rockwell L33ER controller and the FTV Studio V13 as Supervisory computer...
140
Hello Friends I have a backup that I am trying t open in mi PC (RSLogix 17.01) and I get this message. I have read many posts and done many...
186
Hi, Im trying to open an old old Siemens WinCC project. It doesnt have to run i just want to look at the project in WinCC explorer. Its...
704
Hello. I cannot change the SendClock settings for a PROFINET IO device. I need to slow down the CODESYS PROFINET IO controller. What am I doing...
215
