Can't connect to PVP - VMware
rQx
Oct 2010
Trelleborg
1,051
Hi!
I have the following setup.
VWware - Windows 8 - **** ecatcher - PVP6
I have set up the VMware to NAT and I can succesfully ping my PVP6. But when I try to download a program through FTV Studio I can't. I open RSlinx and can't get connection there either.
I'm pretty novice on Rockwell so I could easily do something wrong here
/Tim
I got some more info on this case. I can use a vnc viewer in the vmware player to mirror the panelview aswell, indication that I have connection
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
54
335
121
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
150
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
366
