Can't resolve 1756-EN2TR network I/O Error
MartyMaucher
May 2014
Pensacola
91
The controller is talking on a DLR network to 2 other I/O chassis which I can ping and connect to with RSLinx. But, Logix Designer keeps showing the yellow triangle on the network card and can't see it to reset any I/O errors.
The controller window displays "Object Mode Conflict". The firmware is the same and up to date. Any ideas?
Go to the module properties (the module working as ring supervisor), network tab, and look for the information on "ring fault" section.
I checked the network properties for the ring supervisor, and it doesn't show any errors (neither does the DLR tool). I think the network is ok, but the controller and I/O rack are somehow incompatible (?) i.e. "Object Mode Conflict"
Downloadable .ACD project file: https://drive.google.com/open?id=0B_OlFNbBQXctX2ZYeVRpZnJBaWM
We switched from a SLC5/04 to a 5069-L320ER, and the SLC's NI4's were replaced with the 5069-IY4, which is a pretty neat card; however, the IY4's...
1,766
First time posting. I'm just a mechanical engineer trying to be a programmer so bear with me on some potentially stupid questions. I'm attempting...
4,387
Hello, I'm creating a small application to operate a valve on an existing application between a CompactLogix and a FTView SE instance. I...
1,487
Hi Guys; I am getting this error when I try to reference anything in my template with a different reference then the name of the IO attribute...
2,702
hello Experts... I come across a IB32 DI module with fault code 16#0109 , How should i resolve it. Or I should replace the module with new one...
4,074
