CC Link Communication
desuhardi
Oct 2005
Indonesia
46
Hello,
Our shuttle cars are using optical repeater AJ65BT-RPI-10A/B cc-link to communicate with master PLC (Mitsubishi Q). But car's wheel and runway reel often has some problem, shuttle car can't move smoothly, then error in cc-link.
Is it possible to use wireless for cc-link ? Length is about max 70m.
Thank you
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
115
I have an Omron NX PLC NX1p2 which Supports EtherCAT . also I have Balluff BNI00HA Ecat Block(IOlink Master). I have setup communications and...
169
hello, everyone. I have problem about communication using pncan link. In my case communication Digital Input and Digital output is already...
1,317
Hi; We have been searching a device which can enable an alarm contact if Ethernet communication breaks between a PC and LAN. Application is...
1,557
hi all, what's the best way to check the com link between PLC and FTView site edition ? i have a task to run when the link is broken Thanks
2,458
