CCW Alarm Que
The value of Alarm[0].0 is shifted with a length of zero only to activate the Control[0].UL.
Cycle scans are looking for the bits in the Alarm[2] and[3]. Once one of the alarms is true in the DINT's the GEQ is true allow the mov and copies.
Here is the same code in RSL500. The difference here is the data type INT.
Whoops, I noticed that control .LEN value of 0 before but forgot about it, assuming it was 64.
What controls the value of Alarm[1].0 over time?
Where and how does the other code look for bits in DINTs Alarm[2] and Alarm[3]?
The value of that bit is controlled by the BSR. That is the only instance of that bit in the program.
I don't understand the last question. What other code?
the other difference is that it COPies the string message at offset 65 to itself, instead of COPying the null message at offset 64 to offset 65; is that a typo?
That cannot be correct; the BSR insturction only reads (examines) the value of its Source parameter bit (Alarm[1].0; it cannot write to the Source parameter bit.
I want to create a screen in Connected Components Workbench (9.0) that displays a list of the currently active alarms. In FTView I would use the...
2,427
When creating an alarm for Panelview 800 I am getting the error message that an alarm is no message configured, but the text column to be...
2,361
my ccw softwer stops working when i add and try to open a ladder program.
85
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
142
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
299
