Ccw v11
besc
Mar 2014
California
36
Been out of the loop for awhile but like Test below I am back. I left off with V8 something. It had that annoying collor transition for blocks. Please tell me V11 got rid of that. Mike.
I'm not sure I know what you mean? I've been using CCW since V6 and I now have V11, I can't find any problem as of yet. I've had it since it was released.
I still don't see a problem!
All of that is programmable by the end user, so you can make it any color you want.
I use different color for different groups, if I'm working with digital inputs they might be "a soft green", if I'm working with analog inputs I might use a light blue. Be able to adjust colors is a great programming tool, I use all the time.
So when i would program a drive with CCW i would usually print to PDF the parameters of said drive so it can be archived. this was quite easy in...
2,750
Hey All. I had a regional Rockwell Component Specialist tell me yesterday that CCW V11 was available for download.... I can't seem to find it...
2,133
77
Hey out there, I am trying to build an alarm que in CCW. I have got the FFL and FFU working, however the string that goes with the alarm can't be...
38
487
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
129
