Changing S5 945 CPU
Oct 2006
Ontario
18
Hi, I have a Siemens 945 CPU that I need to change, I did get a new CPU 945, put it on the rack, insert the flash memory from my previous CPU, do I need to do something special for the CPU to load and execute the program from the flash memory cards? Thank you
I think you have to reset the CPU, then it will read from the flash... again I think so if you cant afford to loose any information that is stored wait for someone else to say this is correct
If you are just testing this CPU and rack then try this
If you have 2 switches, 2 position run/stop and 3 position NR/RE/OR
For a normal reset put the switch in the nr position take the other switch and put in from run to stop to run, this will reset the CPU
If you hold the switch in the OR position and move the other switch from the run/stop/run this will clear the CPU memory....
*** you can and will loose your program *** make sure you have a current copy of your program you will need to reload it
I think this will work on yours, good luck
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
267
Hi all, I am having an issue where some of my HMI push Buttons and Indicators go in to error when I navigate to a new screen. I am using a...
506
We have a new machine that uses an armor block to transfer input signals for conveyor position that continuously alarms out on no position change...
103
Hello everyone, I am trying to change the IP address of the Omron PLC (NJ30-1200) and HMI (NB7W-TW01B) to fetch the network on our network...
306
Dear Experts, I'm just started working with GEO SCADA and I need your valuable help. Currently, I'm trying to edit the alarm limits on MIMIC...
228
