Codes in PLC
jayshah11
Feb 2003
23
Hi
I would like to know how are these codes assigned to different parts of the Ladder Diagram. Is there a guide or a manual for that. For example 0001 for start swith.
Jay
I think that the code you are referring to is more like an address.
For instance an input card or an output card.
If you look at this recent post: http://www.plctalk.net/qanda/showthread.php?s=&threadid=2486
you will see what I mean.
Inputs
0000
0001
etc
Outputs
0500
0501
0502
etc
Internal Coil
1000
1001
1002
etc
These aren't the same for every PLC though for instance on a GE 90-30 PLC inputs are in the form of %I1, %I2, etc and outputs are %Q1, %Q2 so depending on the PLC you are using you will have different methods of addressing your inputs, outputs, timers, counters, and registers as well as any other functions the PLC may offer. So whichever PLC you use you will need to learn the addressing scheme that goes along with it.
Codes in PLC II
Ok I understand that there are different codes for different p=PLCs. I would like to what particular PLC are you talking about with these codes. And can i get a code manual for that one?
Jay
Phil's tutorial
If you are referring to the tutorial on the site - there is no such PLC.
Phil Melore wrote the tutorial to be non-brand specific. So you won't find any real PLC using exactly that kind of addressing scheme, although some will come closer than others.
There's a thread in the old forum where we catalogued various PLC brands addressing structure. Perhaps that will help you.
CLICK HERE
Jay, you are probably best served by doing three things:
First, do the tutorial on this site and purchase Phil's book for reference.
Second, go to a couple of PLC manufacturer's sites and get the catalogs sent to you, or review them on line. Here are a couple:
http://www2.automationdirect.com/store/Home/Home
http://www.ab.com/plclogic/
Third, download the manuals for a couple of PLCs and scan through them, looking for similarities and differences.
Then come back here with more specific questions. We will be very glad to help, but we can't do a turorial one question at a time on the forum.
What PLC Important?
Hi
I am going through the manuals of Allen-Bradley SLC 200 and GE 90-30. I would like to know that to get into the job market right now which are the most important PLCs used so that i can start reading on them and get back here with the questions?
Jay
Hi there I wonder what is going on the following codes works (I mean runs and cycles until I press x1 button) in simulator, But It does not...
1,233
Hello all, I'm thinking about how helpful could be adding a HMI screen to display the faults or errors that can happen to the PLC. I usually use...
3,076
hi everybody, i need to send hex codes (FC 40 32 00 91)from omron cqm1 plc to stepper motor drive through serial rs232c to start and stop that...
2,003
Hello peeps, i'm doing a Visual basic6.0 program codes to communicate with PLC unit(NAiS FPG-C32T2) via a RS232 link.. what i...
18
9,938
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
135
