Codesys - Create Boot Project Not Shown
Esieli
Nov 2018
Georgia
64
Anyone have some advice? I build the project and have no errors. I can login and logout, but never have the ability to create a boot project or download to the PLC.
Any help would be appreciated.
Thanks in advance!
Thanks in advance!
It's in simulation mode. I just need to figure out how to turn it off. The button for simulate is grayed out regardless of what I do and what mode I put it in. I also tried typing it in the command line. No luck...
I don't have all the answers for Codesys, but from my past experience, I took it in and out of simulation mode under the Online tab. Is that what you are referring to is grayed out?
Just for the sake of adding to this thread for someone in the future, the problem was no target was selected. If no target is selected, it will treat it as a simulation.
Another note is if you add a target, which you will have to, it will wipe your PLC IO configuration. I read somewhere that there's a way you can save it as an XML and bring it in, but I didn't find how to do it.
Thanks!
Hello, I am using a Hitachi Micro EHV+ for a small project, and I wanted to have a Web visu, done with Codesys V3.5 SP13 Patch 2. I test the...
298
Hello, I have a requirement to manage the text alignment dynamically. So, for example: 1. English Texts should be displayed from Left in...
90
Hello, I am new to Codesys, and am trying to learn about it for a project we're developing. I've got a couple questions, but first a little...
162
Hi everyone, as this is my first experience with Rockwell Software i would like to know what's the best way to make Enumerations?
512
I am trying to get Codesys to work with a couple of Moxa ioLogik E1200 series DIO devices (E1210 and E1211). I am able to write to the E1211 DOs...
178
