Communicate PCMK to ML1500
delt
Mar 2006
Chih
19
I have a ML1500 and a PV300 connected in DH485 configuration by using a 1747-NET-AIC
Since my Laptop does not have a serial Port I decide to use the 1784-PCMK/B whit the Cable 1784-PCM4/B. The Problem is that this cable has a RJ45 termination and I need DB-9 connector for the 1747-NET-AIC conetion.
I was wondering if somebody have the pinout of this cable (1784-PCM4/B) in order to build my own interface (RJ-45 to DB9)to communicate with the 1747-NET-AIC.
Thank you.
I'm not sure you can connect with the ML1500 and the 1761-AIC+ with your PCMK card.
I think you will need the 1747-UIC or a PC with a real serial port and the 1747-PIC/AIC driver.
Lets us know if you make it work thought.
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
70
HOW to communicate with OPTIX and Mitsubishi's Q Series PLC?? PLEASE HELP ME
81
We are trying to poll data coming from a PLC for remote monitoring we have the IP address of the PLC and the default port number and the path is...
25
622
We have some very old technology in my plant that needs adjusted but I don’t have the equipment. Can anyone tell me what I need to program this IO...
391
Hi Guys, I want to connect my 1769-L36ERM to a different network domain, is it possible to do it using only the dual ports in the Controller? Or...
246
