Communication cable for GE FANUC 90-30 plc ?.
hinddhindsa
Mar 2013
www.plckart.com
193
Hi Dear friends,i need a communication cable for GE FANUC 90-30 series plc,power supply is IC693PWR321 and IC693CPU313x is CPU(5 slots base plate). Do i need to buy a cable for it or shall i make a cable of my own.help me.thanks.
time out error
whenever i tried to connect through that cheater cable, it gives me time out error, i tried many times. could you tell me what the baud rate i should set. i am keeping at 19200, odd parity.
I have used a cheater cable like it on hundreds of PLCs and dozens of computers without an issue. If it does not work for you either the cable was not made to specifications or there is another problem.
If the original system was designed to use a modem try 9600, no parity.
Does anyone know what software the IDEC FA-2J Controller uses? And what cable is needed to communicate? I can barely find any information on this...
1,140
Hello guys, I need to change the configuration on an C200HW-PRM21 PROFIBUS-DP Master Unit and looking communication cable. Any one knows where...
1,220
Hello everyone, From experience which is better for field use, 90 deg or straight and why? I a inclined to buy the straight one but started...
2,131
hi i know that it require wire gaure 18 but i just want to know is that posible to use eternet wire as a io communication wire. (because it cheap...
1,443
Hello gents, Is the communication cable for the Lenze 8400 a USB to RS485? And if so can I use the Schneider one? Thanks Kal
2,335
