Communication with SINAUT-8-FW RTU
Sanjay200768
Apr 2005
Hi Folks,
Does anybody has experience communicating with Siemens' SINAUT-8-FW RTUs? The communication protocol itself is also called SINAUT-8-FW. The RTUs are confiured to communicate using DPDM (Digital Pulse Duration Modulation) which is quite different from the way the RS232 port of the PC works.
My problem is that I do have details of the communication protocol and I can write a driver for it but I do not know how I can read/transmit DPDM messages from a normal PC.
Any Suggestions?
Best Regards
Sanjay Malhotra
Hello,
I know that Novotek (www.novotek.se) wrote a FIX driver for Sinaut once upon a time. If you are running IX or iFIX maybe you could buy a complete driver from them.
Hello, I am currently in the final week of my internship and I have encountered issues with communication between a PowerFlex 700 variable...
23
Hi all. I have a Modbus ProSoft module in my setup with a capability of 30 clients (0-29), which I'm trying to monitor the Ethernet Connection...
34
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
171
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
46
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
47
