Compact Logix L32E/L30ER printing to Ethernet Printer(Zebra)
We do printing to Zebra's over TCP Socket frequently, works just fine. We also do it with Siemens, which is just as capable with a CP card installed. Your ZPL build strings are the same as they would be over RS232, its just a different chunk of code to get them to the printer over TCP/IP.
Do you mean Ethernet/IP with special firmware? or straight from Compactlogix/Contrologix to Zebra with an RTA Gateway?
Just straight from the processor/Ethernet Module. What is the PN of your Ethernet Module? ENBT/EWEB/EN2T, etc. Some of the older modules don't support socket interface.
I dont have a particular one, but it can be a compactlogix. Did you use version >v20 with Zebra LinkOS AOP or a generick E-net module define with I/O Assembly instance?
Hi Travis, can you share the one with siemens?
*I know this is kind of a dead thread but if anyone is looking for some information I didn't see listed above see below
I used an HMI Macro (Weiktek). To take the data that we needed to print and send it to the printer from an 1769-L32E. It works pretty well. The only issue I had with it as I had to send multiple prints and it would send them too quickly and the printer would miss a couple. But overall it did the trick!
I'm not sure if the factorytalk HMIs allow TCP/IP communication but depending on what HMI you are using you could do it there. There is a website to set up the labels here and get the code
All, I have a system on a CompactLogix L32E with Devicenet. I need to flash the 1769-SDN Devicenet module to a higher rev. after flashing up the...
1,255
Im on site, there was water damage in the cabinet. Trying to see what i can do Right now here is there. I can see all inputs, and LEDs work...
2,603
Hey Guys, Just learned Rockwell stopped selling these two processors as of 12/2020. The web page recommends moving to the 5380 platform. Are...
1,722
Good morning, I am having some issues connecting to my plc via ethernet. There is a 9-pin RS232 I can connect to however. The ethernet cable...
1,913
I am trying to setup communications between an m580 and a compactlogix plc. I have confirmed my set up on schneider side is correct and now I am...
3,046
