Matthias von Zorn
I have a compact logix L32E, and RSLinx is not recognizing the device. I am connecte d to it by a crossover ethernet cable. Ive used bootP to assign it an IP (192.168.0.1). I can ping the IP. When I used RSLinx (v 2.42) as ethernet devices (AB_ETH1), it sees the IP, sees the "online name" as "1769-L32E Ethernet Port). But, the device tupe is "Unrecognized device". The "status" is unknown. If I use ethernet/IP instead, it does the same, only it also sees the status of the device too. Still has "Unrecognized device" tho. Because of this unrecognized device, I cant select it as a path to download the program too. Or upload or go online for that matter.
I have rslinx gateway v2.42 and RSLoigx 5000 enterprise v13.0 on windows xp sp1
edit: Also, the read me for 2.42 say that the L32e is added in that revision.
Matt
Matt
