compact & modular plc systems
adel
Guest
A
i am going to use plc controller system . how to use manufacturing data ,trade publicatios and catalogues. how to select two plc systems
to meet the requirements below.one must be modular and one must be compact.
1- mains powered. 2- digital inputs 15x24v opto isolated. 3-digital outputs 9x30v relay @1A. 4-analogue inputs 2xmaximum input voltage+10v.
5-analogue input 1x4-20mA.6-analogue outputs 2xmaximum output voltage+10v. 7-temperature sensorbinput 1x-10 to 150c input range.
i need the list of components for each system.
brief descriptions of each system.
the total cost of each system.
a brief discusion on consideratiom given to alternative cofigurations of units modules during the selection of each system.
the suitsbility of each system to be expanded to a further 50% of its current I/O capability. with the photos of each system . thanks alot
OK, Adel, what exactly are you asking for? I don't see a single specific question in your post!
Please note, we won't do your homework for you, but if you have a question sufficiently narrow in scope to be covered by one or two paragraphs, we will be happy to answer it.
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
133
What happens if you power up a 1783-MS10T with a Compact Flash card from a 1783-MS06T? Does it work, but with the "extra" ports unconfigured? If...
96
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
136
My PLC is currently running the program and the process is still live. One of my 1769-if16C cards values are all frozen but the card is not...
135
I've blown the Output Transistor on the Output Card of a Compact Logix 1769-L24ER-QBFC1B It says J378. Does anyone know the replacement part...
209
